September 25, 2020, 10:42:54 AM *
Author Topic: Legends: Heart Gold Soul Silver Coverege  (Read 46530 times)
Scott Omlo
« on: November 14, 2009, 07:16:16 PM »
Okay, so I feal Like MFM should be checking out some of the new Sets coming out for the Pokemon TCG. So to start it off i would like to do it on the New Set: Legends: Heart Gold Soul Silver.
Basic Information:
Pokemon TCG Legends: HeartGold Soul Silver will be released in Febuary 2010
-This set marks a new set block - LEGEND. The previous set block was Platinum, and the one before was Diamond and Pearl.
-The “set” is divided into two mini-sets - HeartGold Collection and SoulSilver Collection. Our English set will combine both sets. Each pack costs 315 yen and contains 11 cards, including two holos (one regular holo and one reverse holo) and a redesigned basic Energy card.
-A “Random Basic Pack” containing 60 cards will be released at the same time for 1400 yen. 30 of the 60 will be random cards from the set, six of those 30 will be holo cards, and the other 30 cards will be basic Energy cards. The pack also comes with a bonus Red Gyarados card.
Changes to the TCG:
-Legendary Pokemon cards now replace LV.X Pokemon - they are oversized Pokemon split into two cards that you have to place together to use. One card features a huge chunk of artwork of the Pokemon while the other card features its attacks - putting them together forms one complete card, as seen in the images below. For the purpose of using powers and Trainers, Legendary Pokemon cards are treated as their own subclass, much like Basic Pokemon cards, Evolution cards, LV.X cards, and so on. To bring a Legendary Pokemon into play, you must collect both halves of its card, then play both cards at the same time onto your Bench. Due to the nature of Legendary cards, they can’t be played during setup. The two halves of the card are numbered differently, but since they both have the same name, it’s likely that you can only run a total of four halves in a deck (two complete cards).
-Great Pokemon, a new type of card, are described as Pokemon that “specialize in battling,” but they do not seem to have any sort of new mechanics tied to them as of yet. They are simply regular Pokemon cards. You can evolve Totodile to Croconaw and then to Feraligatr (a Great Pokemon) like any other evolutionary line. Perhaps they can be considered stronger Pokemon, as evidenced by Feraligatr’s Pokemon Power. There will be eight in the set.
Starting with this set, Japan will now get reverse holos in their booster packs. Each booster pack comes with 11 cards: one holo, one reverse holo, one energy, and eight other cards from the set. With every two booster packs a person buys of this set, they will receive one of six promo cards. Three new tournament promos will also be released after this set is released - Meganium, Typhlosion, and Feraligatr.
-“Trainer” cards are now called “Goods,” which is the Japanese Pokemon term for “Items.” Thus, we will now have Goods cards, Supporters, Stadiums, and Tools. This is probably to clear up past confusion caused by calling all non-Pokemon and Energy cards “Trainer Cards” while also having basic “Trainer” cards. Existing “Trainers” will be treated as Goods when interacting with cards from the LEGEND block.
For this set block, each card will feature a gold and silver border in obvious reference to HeartGold and SoulSilver. The template for Pokemon cards is now also slightly updated - the evolution box is next to the Pokemon’s name and the coloring behind the HP is now white. Great Pokemon have a special border around the artwork, the artwork seems to be zoomed-in to their faces, and their names are holo.
Set Information
-There are 70 cards in each of the two mini-sets.
-One secret card per set - Alph Lithograph.
-No overlap between the two sets, except for eight basic Energy cards.
-The sets will feature redesigned basic Energy cards. Each Energy type will also apparently feature silhouettes of certain Pokemon.
-The English set should have 150 cards, excluding any promos added in.
Below are the Legends with their translations...
Hoho
#15 - Ho-oh LEGEND - Fire - 140 HP
Legendary Pokemon
Poke-Body: Sacred Rainbow
All Energy attached to this Pokemon becomes Fire Energy.
[R][R][R][R] Crimson Wing: 100 damage. Discard 1 Energy attached to Ho-oh LEGEND.
Weakness: Water (x2)
Resistance: Fighting (-20)
Retreat: 2
Combine 2 Ho-oh LEGEND cards from your hand and play them onto your Bench.
Lugia
#29 - Lugia LEGEND - Water - 130 HP
Legendary Pokemon
Poke-Power: Ocean Glow
You can use this power once during your turn, when you bring this card into play. Look at the top 5 cards from your deck and attach every Energy you find to this Pokemon. Discard the remaining cards.
[R][W][L] Elemental Blast: 200 damage. Discard 1 Fire Energy, 1 Water Energy, and 1 Lightning Energy attached to Lugia LEGEND.
Weakness: Lightning (x2)
Retreat: 1
Combine 2 Lugia LEGEND cards from your hand and play them onto your Bench.
New Energys:
You will be getting one of these energys per Pack, I will find the other to in a good size soon.
Promo Cards:
Note: Translations are Below in the same order as the Pictures
Chikorita – Grass – HP50
Basic Pokemon
[C] Nap: This Pokemon’s HP is restored by 10.
[G][C] Dash: 30 damage. This Pokemon does 10 damage to itself.
Weakness: Fire (x2)
Resistance: Water (-20)
Retreat: 1
Cyndaquil – Fire – HP40
Basic Pokemon
[R] Fireworks: 20 damage. Flip a coin, if tails discard 1 Fire Energy attached to this Pokemon.
Resistance: none
Retreat: 1
Totodile – Water – HP60
Basic Pokemon
[W][C][C] Aqua Tail: 30 damage. Flip a coin for each Water Energy attached to this Pokemon, and this attack does an additional 20 damage times the number of heads.
Resistance: none
Retreat: 2
Mareep – Lightning – HP40
Basic Pokemon
[L] Static: 10 damage.
Weakness: Fighting (x2)
Resistance: Steel (-20)
Retreat: 1
Teddiursa – Colorless – HP50
Basic Pokemon
[C] Fake Tears: Flip a coin, if heads, during your opponent’s next turn your opponent can’t play any Goods cards from his or her hand, and any damage done to this Pokemon is reduced by 30.
Resistance: none
Retreat: 1
Phanpy – Fighting – HP60
Basic Pokemon
Poke-Body: Thick Skin
As long as this Pokemon has Energy attached to it, any damage done to this Pokemon by attacks is reduced by 10.
[F][C] Rock Smash: 20 damage. Flip a coin, if heads this attack does an additional 10 damage.
Resistance: Lightning (-20)
Retreat: 2
Meganium – Grass – HP130
Stage 2 – Evolves from Bayleef
[G] Sleep Powder: 30 damage.
Second Attack Unknown
Weakness: Fire (x2)
Retreat: 2
Feraligatr – Water – HP130
Stage 2 – Evolves from Croconaw
[W][C][C] Spinning Tail: Does 20 damage to each of your opponent’s Pokemon. (Don’t apply Weakness and Resistance for Benched Pokemon.)
Weakness: Grass (x2)
Resistance: none
Retreat: 2
Typhlosion – Fire – HP130
Stage 2 – Evolves from Quilava
[R][C] Magma Punch: 50 damage.
Resistance: none
Retreat: 1
Hoothoot - Colorless - HP50
Basic Pokemon
Poke-Body: Insomnia
This Pokemon can’t be Asleep.
[C] Peck: 10 damage.
Weakness: Lightning x2
Resistance: Fighting -20
Retreat: 1
Noctowl - Colorless - HP90
Stage 1 - Evolves from Hoothoot
Poke-Power: Night Scope
You can use this power once during your turn. Look at your opponent’s hand. This power can’t be used if this Pokemon is affected by a Special Condition.
[C][C][C] Hypnotic Wave: 30 damage. The opponent’s Active Pokemon is now Asleep.
Retreat: 1
Victory Medal - Goods
Flip 2 coins. If 1 is heads, draw 1 card from your deck. If both are heads, put a card of your choosing from your deck into your hand. Shuffle your deck afterward.
You can use GOODS as often as you like during your turn.
Professor Elm’s Training Method - Supporter
Search your deck for a Stage 1 or Stage 2 Evolution card and put it into your hand. Shuffle your deck afterward.
You can only use 1 Supporter card per turn.
Copycat - Supporter
Shuffle your hand into your deck. Then, draw cards from your deck equaling the number of cards your opponent has in his or her hand.
Gyarados - Water - HP130
Stage 1 - Evolves from Magikarp
[C] Thrash: 30 damage. Flip a coin, if heads this attack does an additional 20 damage. If tails, Gyarados does 20 damage to itself.
[W][C][C][C] Heavy Storm: 70 damage.
Retreat: 3
Slowpoke - Water - HP60
Basic Pokemon
[C] Raucous Party: Look at the top 5 cards of your deck. Choose any number of Basic Pokemon cards you find there and play them on your Bench. Return the remaining cards to your deck and shuffle.
[W][C] Water Kick: 20 damage.
Resistance: none
Retreat: 2
Slowbro - Water - HP90
Stage 1 Evolution - Evolves from Slowpoke
[C] Complete Refresh: Remove 30 damage and all Special Conditions from this Pokemon.
[P][C][C] Surprise Trip: 50 damage. Flip a coin, if heads the opponent’s Active Pokemon is now Confused. If tails, this Pokemon is now Confused.
Resistance: none
Retreat: 2
Slowking - Psychic - HP100
PokePower: Your Choice
You can use this power once during your turn. Reveal the top 2 cards from your deck, and your opponent chooses 1 of them. Put the chosen card in your hand, and return the other card to the bottom of your deck. This power can’t be used if this Pokemon is affected by a Special Condition.
[P][C][C] Super Psy: 60 damage.
Weakness: Psychic x2
Resistance: none
Retreat: 2
Lugia - Water - HP90
Basic Pokemon
[W] Spash: 20 damage.
[W][W][C][C] Aeroblast: 50 damage. Flip 2 coins, this attack does an additional 20 damage times the number of heads.
Retreat: 2
Ho-Oh - Fire - HP100
Basic Pokemon
[R] Combustion: 20 damage.
[R][R][C][C] Sacred Fire: Flip a coin, if heads this attack does 80 damage to 1 of your opponent’s Pokemon. Don’t apply Weakness and Resistance for this damage.
Weakness: Water x2
Retreat: 3
« Last Edit: December 10, 2009, 08:13:27 PM by Scott Omlo » Logged
mjdkernow
« Reply #1 on: November 20, 2009, 12:14:19 PM »
As expected, the next English set is HeartGold & SoulSilver, retaining the same name as the Japanese set but without the "LEGEND" title. The only change known so far is that "Great Pokemon" will now be called "Pokemon Prime." The set will be released in stores on February 10th, meaning prereleases will take place the weekends of January 30th and February 6th. Based on the set's release date, we can also expect the video games to hit store shelves within a month or two afterwards in perhaps March or early April.
As with all sets, there will be several products sold alongside its release: a three-pack blister pack with an unknown promo card, a poster pack with either a Lugia or Ho-Oh promo, and three Spring 2010 Collector tins with four booster packs and alternate art promo reprints of either Prime Meganium, Prime Typhlosion, or Prime Feraligatr.
« Last Edit: January 07, 2010, 10:40:24 AM by admin » Logged
Pee-Oh-Kay-Eee'-Em-Oh-En.
