April 21, 2019, 10:45:25 PM *
Author Topic: Yugioh Card errats worth a read  (Read 3280 times)
« on: August 03, 2009, 06:22:48 PM »
From the YuGiOh 5Ds Starter Deck:
Colossal Fighter
5Ds1-EN043
Printed Text:
1 Tuner + 1 or more non-Tuner monsters
This card gains 100 ATK for every Warrior Type monster in any Graveyard. When this card is destroyed by battle and sent to the Graveyard, Special Summon 1 Warrior Type monster from either player's Graveyard.
Correct Text:
This card gains 100 ATK for every Warrior Type monster in any Graveyard. When this card is destroyed by battle and sent to the Graveyard, you can Special Summon 1 Warrior Type monster from either player's Graveyard.
From Crossroads of Chaos:
Black Rose Dragon
CSOC-EN039
Printed Text:
When this card is synchro summoned you can destroy all cards on the field. Once per turn, you can remove from play 1 Plant-Type monster from your Graveyard to change 1 monster your opponent controls to face-up Attack Position, and reduce its ATK to 0 until the End Phase.
Correct Text
When this card is synchro summoned you can destroy all cards on the field. Once per turn, you can remove from play 1 Plant-Type monster from your Graveyard to change 1 defense position monster your opponent controls to face-up Attack Position, and reduce its ATK to 0 until the End Phase.
those are the main two that most people use.
other errats are on the following cards:
Gigantic Cephalotus
Jade Knight
Morphtronic Accelerator
Poison Chain
Indomitable Gladiator Beast
Earthbound Immortal Aslia piscu
Koaki Meiru Powerhand
Double Tool C&D
Light End Dragon
Green Baboon, Defender of the Forest
http://www.yugioh-card.com/en/gameplay/errata/YGOErrata090730.pdf
« Last Edit: August 03, 2009, 07:13:08 PM by admin » Logged
Scott Omlo
Guest
« Reply #1 on: August 03, 2009, 07:09:48 PM »
Its kinda obviouse about Black Rose Dragon, I see the confusion with collosal fighter. And I really want to see the thing about indomitable glad beast.
Rob
« Reply #2 on: August 05, 2009, 01:39:55 PM »
Even more important you want to read the card rulling change on green baboon.
