Just thought id point out that you dont need to have any Necromunda models to play - alot of the 40k range is suitable...
Catachans work well as Orlocks or Goliaths
Cadians could work as van saar with a little work
Cawdor could be created using plastic imperial guard bodies, and either a little bit of green stuff for hoods, or even wood elf glade gaurd heads.
Ive even seen someone use the goliath rules for an Ork gang
Ive got no problem with somebody creating there own house/gang, based on one of the 6 normal houses in the book, if it gets people playing then its all good
Cheers
Matt
