February 22, 2019, 11:01:07 PM *
Author Topic: Official time on the round procedure  (Read 1742 times)
« on: January 17, 2012, 10:10:22 PM »
F. End of Match Procedure – Swiss Rounds
There are times when a Match will not be completed when time is called in the round. Should this situation arise, Duelists must follow the following procedures to determine the outcome of the Match.
This End of Match procedure will only be used at Tier 2 events.
If time is called during the Duel in Swiss Rounds
1. Continue until the end of the current turn.
2. If the Duel did not end at the end of the Turn, go to “Extra Turns.”
o Extra Turns = Conduct 5 Turns starting from the opponent’s Turn.
3. If a victory condition (a Duelist’s Life Points is reduced to 0 or an instant win condition such as with Exodia the Forbidden One) occurs within these 5 turns, the Duel ends as normal.
4. If a win condition does NOT occur within these 5 turns, the Duelist who has higher Life Points after the Extra Turns (5 turns) wins.
5. If both Duelists’ Life Points are the same after the Extra Turns are completed (5 turns), the Duel is considered to be a Draw.
How to decide the winner
 After the Duel is concluded, the Duelist with the most Duel Wins is declared the winner of the Match.
 If both Duelists have one Duel Win and the third Duel ends in a Draw, the Match is considered to be a Draw.
 If time is called before a Duel begins (during Side Decking, before drawing their opening hands), and both Duelists have the same number of Duel Wins, the Match is considered to be a Draw.
 If time is called before a Duel begins (during Side Decking, before drawing their opening hands), and one Duelist has more Duel wins than the other Duelist, the Duelist with more Duel wins is declared the winner of the Match.
 Duelists may not choose to intentionally end a match in a Draw. Intentionally ending a Match in a Draw, or stalling to have a Match end in a Draw, is against tournament policy and could result in a Disqualification.
G. End of Match Procedure – Single Elimination Rounds
If a Match does not finish within the allotted time amount in a Single-Elimination tournament, the result will be decided by the methods below.
This End of Match procedure will only be used at Tier 1 events and in the Single-Elimination rounds of Tier 2 events.
2. If the Duel did not end at the end of the Turn, go to “Extra Turns”.
Extra Turns = Conduct 3 Turns starting from the opponent’s Turn.
3. If a victory condition (a Duelist is reduced to 0 Life Points or an instant win condition such as with Exodia the Forbidden One) occurs within these 3 turns, the Duel ends as normal.
4. If a win condition does NOT occur within these 3 turns, the Duelist who has higher Life Points after the Extra Turns (3 turns) wins.
Yu-Gi-Oh! TCG Tournament Policy 12
5. If both Duelists’ Life Points are the same after Extra Turns (3 Turns), continue on to a sudden-death playoff.
6. In sudden-death, the Duel ends when there is a Life Point change for either Duelist.
This includes paying Life Points as a cost or gaining Life Points.
7. The Duelist with the highest Life Point total after the Life Point change is declared the winner.
If time is called before the Duel (during Side Decking)
1. If one Duelist has more Duel wins than the other Duelist, the Duelist with more Duel wins is declared the winner of the Match.
2. If both Duelists have the same number of Duel Wins, begin a new Duel which consists of 4 Turns and each Duelist begins with 8000 Life Points.
3. The Duelist with the highest Life Points at the end of the 4th turn wins the Duel.
4. If both Duelists’ Life Points are tied at the end of the 4th turn, continue on to a sudden-death playoff until the winner is decided.
« Last Edit: January 20, 2012, 11:32:11 AM by admin » Logged
