June 18, 2019, 04:44:25 AM *
Author Topic: problem with daemons in KR trays  (Read 4083 times)
« on: January 14, 2011, 04:47:11 PM »
i have some kr tarys but cant seem to get them in the slot as theyre wider (sword or arms are stickin out)
is there a wider tray or should i get the 51mm tray nd have them stand any suggestion
Darak Vardek
« Reply #1 on: January 14, 2011, 08:45:25 PM »
which daemons?Huh?
« Reply #2 on: January 14, 2011, 08:56:07 PM »
pink horrors & bloodletter
Darak Vardek
« Reply #3 on: January 14, 2011, 09:11:59 PM »
well usually it helps to check as u assemble the models so u build them to fit next to each other and mark the underside of the base so u know where each one goes, i learnt this from the previous chaos warriors.
if their already built just juggle them about to get the best possible fit them mark them
« Reply #4 on: January 15, 2011, 09:00:27 AM »
no i can get them on the movement trays ok but its fitting them into the carry case  Grin
« Reply #5 on: January 15, 2011, 09:20:21 AM »
Ive always found the trays that allow the model to "stand up" to be more useful for Fantasy chaos armies, the Kr range includes several pick and pluck trays that allow you to tailor the case to your army.
Hope this helps.
Matt
« Reply #6 on: January 15, 2011, 09:25:11 AM »
thx thats what i was thinkin
Do you have these in the store?
« Reply #7 on: January 15, 2011, 10:03:47 AM »
They can be ordered in, Give Vini a call and he will sort you out  Smiley
« Reply #8 on: January 15, 2011, 10:44:21 AM »
ok thx
« Reply #9 on: January 15, 2011, 09:26:52 PM »
Hi, getting any case foam or case for that matter is no problem - im hoping to do a multi case order this week so if you let me know before Tuesday what yor after I can get it in for you this week if you like!
